central heating flusher
17 Nov 2008
Lancashire
Ive just hired a central heating flusher and just been in the loft while it was running found the header tank filling up the instructions are not clear am i supposed to be draining at the same time when its running? thanks :?
coldroy
No your meant to know what uour actually doing before startin.
The cold feed and open vent need capping
Obviously got it wrong the mains feed into the tank i have turned off and the open vent is that the pipe going into the header tank as an overflow ta
coldroy
you need to cap off cold feed and vent before starting to flush, and clean out expansion tank before refilling system.
Hope its not gonna get worse and yes maybe a bit quick with comment just not in the mood at the mo will laugh when i finish if i dont flood the house first
coldroy
Wow didnt realise how much crap a system would hold im now thinking of getting a magnaclean or similer is that diy or gas safe? do you guys reccomend them and thanks for all your replys and help
coldroy
coldroy
Keeping the correct concentration of inhibitor in the system is really important. Yes, a magnetic filter is also a good idea, it can be diyed, doesn't need to be Gassafe. It's only a couple of compression fittings to fit. Put one on whilst you have the system drained. It goes on the return pipe, just before the boiler.
I don't like Magnaleaks, the Fernox tf1 is better.
http://www.fernox.com/equipment/filters/total+filter+tf1
