My CH system is an old single-pipe system about 30 years old. The boiler is about 15 (Potterton Kingfisher II 50, the pump new and most rads have been replaced.
The downstairs rads take a long time to warm up and even then they are only warm at one end and cold at the other. Upstairs is not bad. The header tank fills with hot water hence theres a lot of noise and air in the system. This only started this winter. The furthest radiator is cold, though its never been very warm.. As a test I reversed the pump then the furthest rad was very hot but the rest didnt heat much at all.
I guess there is a restriction but where is it likely to be? I've tried flushing the system and I've cleaned all the rads. They werent too bad.
I thought about converting the downstairs to two pipes while upstairs still one pipe. But it should work better as is.
Any help / ideas much appreciated.
