i have taken the room stat cover off and there are 4 wires, live to No 1, neutral to 2, i guess an earth to 3
i'm using honeywell st9400c timer, hoeywell roomstat, danfoss hsa3 actuater and danfoss wb 12 wiring centre,
Room stat brown (Pos 1) becomes live when CH is turned on, when RS is turned up the green (Pos 3) wire becomes live too
Wiring fault No1 perhaps.![]()
Where is this green wire in the wiring center.
Hi Dan, the 28mm and 15mm pipes run down the conduit at the side of the chimney towards the side of the boiler, what happens there i dont know
Nope definitely a blue in with the brown/white.
There's still a pr missing unless they are wired elsewhere.
There's two browns together, could be anything.
And the wrong colour in with the brown/white according to the information given.
which leaves a missing pair.
i have just reveiwed them again and one came up that mentioned the thermostat earth should be connected to L3 and not the earth, i have red to 1, blue to 2, yellow to 3 and the earth to the earth in my new honeywell thermostat, should the earth be connected in with the yellow wire to number 3?
Clearly those 'knots' in the cables create an inductance and prevents the circuits operating correctly as a result of the increased impedance!
