I am looking to using two layers of polystyrene slabs to get me to the proposed floor level in a large ground floor extension and conservatory.
If I cut a channel in the bottom layer to run the radiator pipes in and then cover with the top layer of polystyrene should this be OK, the top slab will be 4" thick and the bottom 3" I am looking to use 15mm either Guest or Hep20 barrier pipe.
Cheers Mick.
Cheers Mick.
