Hi, would appreciate your opinion on a problem we're having with our combi boiler. Vokera 24 e.
The room thermostat calls for heat, boiler fires up as normal, all radiators get hot, after 5 mins or so, the boiler cuts out even though it hasn't reached desired temp on room thermostat. It seems as though when the boiler cools it will eventually fire up again, this can vary in time. When the boiler cuts out, the fans still seem to be running.
Also i've noticed that during this time when the thermostat is still asking for heat and boiler has cut out, the DHW stays cold, until we lower the thermostat so its not asking for heat.
All other times the DHW is fine.
Plumbers are on the case, but at the moment haven't found a cure.
System pressure stays around 1, heat exchanger has been descaled, system flush and filter added, also diverter repair kit been fitted. Could it still be the heat exchanger even though its been descaled and our hot water works fine. Won't be touching the system myself but was interested in what you guys thought it could be.
