Can anyone help.
Recently I had a new boiler fitted(not combi), the pump and 3way valve was under the floor, the plumber has moved them into the airing cupbaord
They are now about 3-4 feet higher. The problem I now have is that the central heating tank in the loft is filling with hot water, this is not from the expansion overflow but from the supply to the system and you can feel it being pumped in. The plumber now says that the tank in the loft will have to be raised up the same as the pump to stop the hot water feeding into the tank. Is this right or is there another problem ?????
