Hi guys,
The heating in the house we recently bought sometimes acts a bit strangely - I'm assuming it's the 2-channel Horstmann H21 programmer, but I'm not entirely sure.
Obviously, I'll get someone in to take a good look but if I can just replace the programmer or thermostat to solve the issue that would be handy.
So..
Sometimes when the heating is due to come on, nothing happens. This only happens once or twice a week - and I think it's usually when we use the "boost" button, not the times schedule.
The pump doesn't circulate and the boiler doesn't fire up, but the "central heating" light on the programmer is on. The thermostat can also be set quite high at the same time, but no heating.
The only way to get the heating on is to use the isolation switch to stop mains power to the programmer for a couple of seconds, then put it back on. The pump and boiler then fire up.
(The programmer turns off when power is stopped, but keeps the timer settings when it's back on)
The programmer itself seems to function OK, screen works fine, settings and buttons all work...
'Twiddling' the thermostat to make sure it's not set too low (hence stopping the heating) doesn't help either.
Any idea's?
A couple of times the heating has also turned on "outside" of the programmed schedule and refused to turn *OFF* until power to the programmer is briefly stopped.
I'm aware that this issue could be unrelated as it could be a pump issue or possibly a zone valve sticking as we had this issue in another house. Turned out to be the pump....and then the zone valve..
Cheers!
Drew
So..
Any idea's?
Cheers!
Drew
