Hi people: i have a few quick questions (probably really easy for you)! about heating that i am not 100% sure about and would like any further help/information on from any top plumbers/heating engineers if i may?:
1) why are air vents (usually on the primary flow to the h/w cylinder, tee'd off just before connection) not allowed to be installed on the return/a return pipe?
2) system boilers/combi's that have aav's built in do not require additional manual/automatic air vents installed on the system do they? apart from rad air vents?
3) room thermostats that do not have an anticipator (which works by the neutral wire): how do they reduce the on/off temp. difference instead?
4) the rotor in a circulating pump is turned by the motor-the impellor is attached to the rotor and drives the water by centrifugal force.
5) what exactly do the bearings do in a circulating pump?
thanks for any help, i appreciate you helping me to learn more. sorry if the ed to check/ask pro's.
