Hi all,
I live in an 18 month old house and have a central heating system which has a heating circuit on the ground floor with a thermostat and another for both floors 1 and 2 combined. I also believe I have a separate circuit to 4 bathroom radiators which when we moved in I was told operated in both summer and winter time regardless of whether the heating was on and heated when the water was on.
I have 3 x electric powered Danfoss 2 port valves in my airing cupboard. The problem I have is that for some reason (possibly the pump) and water tank don't switch off and seem to keep calling for heat when both heat thermostats are off and not calling for heat and the water is not timed to be on i.e. all switched off.
The only way I can get it to switch off is if I move all of the Danfoss valves to manual and then back to auto which seems to work in switching off the tank pump/call for heat - but this doesn't always seem to work!
I suspect one of my Danfoss valves are faulty. Is this the likely cause of my problem or is it something else? How easy are they to change and how do I ensure this is the root cause?
Thanks guys in advance,
Cheers,
Chris
Cheers,
Chris
