Central heating zone valve replacement
27 Sep 2006
Dorset
I've finally traced an intermittent fault in a customer's heating system to a broken valve. I only want to replace the head mechanism, not the whole valve. Do they have a standard fixing arrangement? The system has one Honeywell valve but the broken valve is from Sunvic. Is it possible to replace the Sunvic head with a new Honeywell one? They certainly look like the fixings are in the same place on each.
IMO Sunvic valves are rubbish,,,,,, if you cannot do it yourself get a plumber in to replace it with a Honeywell one,,, you then come back to connect it up
The customer in this case is a friend who's lost her job so it needs to be done as cheaply as possible. Getting a plumber in is a cost she may struggle with. I could get another Sunvic as a direct replacement but I agree with you that they're carp.
If it's one of the new Sunvic valves then you can replace the head, however if it's an old one then you are stuffed :cry:
The head definitely comes off separate to the valve. I just wondered if I could replace the Sunvic actuator with a superior Honeywell one. It's not a problem if I can't as I'll just put another Sunvic one on. It's just that I don't rate them and would rather do the job with better kit.
Sorry, but you can only replace a Sunvic head with a Sunvic head..... same with any other brand I'm afraid...........
In that case, Sunvic it shall be. Many thanks for your help with this, much appreciated.
