Ceramic disc tap replacement gubbins
31 Mar 2006
Leeds
We have some lever type taps with ceramic disc 'washers' in them fitted to our bath, and the hot tap will no longer turn off.
I have taken the tap assembly to bits and found a few bits of plastic have snapped off, so i need a replacement tap top.
The taps are about 4 years old, and were bought from 'the big orange shed' :cry:
Could someone reccomend an online supplier of the bits i need, and is it likely to be a standard fitting?
The simplest answer is to replace the taps with a known brand so that you can maintain them in the future, but you could try Lunns first:
www.lunns.net/tapspares/
When I can't avoid choosing taps for a customer I buy a pair of valve bodies at the same time, so that I know I have spares in stock for that tap when they're eventually needed. If the supplier won't/can't supply the spares then I don't buy the taps.
