ok having a problem with my combi boiler, its a worcester 28si.. basicaly the heating side of things is working but the hot water isnt, when i turn any hot tap on in the house there is very little pressure (seems to have suddenly gone bad) and it doesn't trigger the flow switch in the boiler to fire up the gas...(if i manually flick the micro switch the gas fires) i origionaly thought that maby there was a blockage in the flow switch or that the diafragm had split and had maby blocked something but i took it apart and it seems clean and working, the next thing is the coiled pipework that gets heated by the gas...(the heat exchanger i guess) is this likley to be blocked?? or is there filters in it at all??
any pointers greatly receved!! also the pressure of cold feed to the boiler seems to be good
