I have a Oicos HE12 boiler with Drayton timer control. I have time controller set to heat the hot water between 6:00-8:00 AM and then 8:00-9:00 PM. All along the heater was turned off (due to summer) while the hot water was in Auto... However, at the onset of autumn, I turned the heater on for 1 hour yesterday evening using boost, which ran for an hour and stopped. But, since then the boiler didn't stop. Status is still showing "c" and the boiler is firing up from time to time (the burner light blinking), even when there shouldn't be any demand (after 8:00 AM)... To stop this from happening, I had to switch off the boiler altogether. Which means, I'll have to turn it on manually before 6:00 AM and 8:00 PM everyday and and turn them off once we have enough hot water. I wanted to avoid this manual intervention and go back to the Auto mode. Could Someone please let me know the solution?
Regards,
Arijit
Thatcham
Regards,
Arijit
Thatcham
