I was insulating my 22mm central heating pipes over the weekend with climaflex foam insulation... while I was putting the foam on I thought it was a bit of a loose fit and it is only now that I have finished that I've realised that I bought 28mm size foam instead of 22mm size.
Do you think it is worthwhile removing the insulation and getting the right size stuff?? or not really going to make that much of a difference...
also what is the best way to insulate around difficult to access area where I cant fit the foam on -- loft insulation materialbe any good????
thanks for your help
