CH heating doesn't come on when turned on, but if run hot water from taps etc it will then come on for half an hour or so. Its as though it comes on to replace the hot water used from the taps, though it does heat up the radiators etc as normal, but only remains on for half hour at the most.
Have had a problem with diverter valve which is next to the pump, and someone is fitting a new one for me soon. Is this likely to be the problem still, or could it be something different, ie the pump or the thermostat.
Thanks in advance.
Thanks in advance.
