Hi folks. ive been using/following this site for a while now while I renovate an old house I bought but this is my 1st post...
first the history: I have a very old system that hasn't been updated for probably 30 years or so. I have swapped out all the old (rusted/leaking/broken beyond recognition) plumbing connections and in doing so also replaced all the components for modern units (apart from the pump which seems ok) I have not moved anything the positions are all as before.
I believe it to be a fully pumped S plan system. 2 x 2 port zone valves and a large water fill and small F/E tank in the loft
I have bought a Honeywell sundial wiring centre to help me out which is pretty self explanatory as far as the connections are concerned.
so far i have connected everything apart from the cylinder stat, I was going to use the old switchmaster one that was there but this has different wires and i cannot find any info on it to determine which is which so i will buy a new one tomorrow and fit this in the wiring center shortly
so far i have snipped the links as per the instructions inside the lid and also joined the room stat terminals as i am not using one (the Hive should be taking care of this) when i switch on the power all is ok, both zone valves stay closed as they should and nothing blows up. But when i click for heating on the hive the system seems to start correctly but then blows the fuse in the wiring centre.
so 2 questions.
1 - Is it ok for the cylinder stat to not be connected for now
2 - and the elephant in the room! and the hell do i do with the Hive heating off wire (as you can see ive just put it in a terminal block while I ask you guys what ive done wrong lol)
if ive missed any relevant info please let me know . thanks in advance
so 2 questions.
