Hi all,
I'm going to be changing all 9 of my downstairs radiators which are about 40 year old type 11, to larger sized type 21 bought super cheap in clearance last year. I have an open vented system and no immersion heater, so want would like input on what is the most logical way to go about it. I would want to keep the system filled for as much as possible with shortest possible drained down period, so we have hot water.
I want to do it as much DIY as possible, but could get a plumber in for a day if it makes sense. The options as I see it are:
Adjusting the pipework first (using push fit) then shutting off the valves and refilling. This would mean super accuracy required in both the pipework and then later hanging the rads in the correct position. I'm not even sure it would be possible?
Shutting off valves, remove old and hang new rads, then getting a plumber in to adjust the pipework after would seem the most efficient way to go. However hanging the new larger rads first may not be possible as the pipes will be in the way?
Any advice would be appreciated.
