changed radiator - no hot water???
22 Mar 2005
Hi Guys
Need a bit of help.
I changed a radiator and now there is no hot water??
there is water coming out of hot water taps but not hot.
the system is a back boiler, but how would this affect the hot water?
thanks for your help
Daz
IS THE HEATING SIDE WORKING OK?IF SO POSS AIR LOCK MIGHT BE AN AIR BLEED ON HOT WATER FLOW PIPE ,BUT REALLY NEED MORE INFO ON SYSTEM TYPE
thanks,
Yes the heating side is fine the rads are heating up ok
sorry all i know at the moment is that it is a back boiler, i am going back tomorrow.
I didnt drain system down but there was a lot of air in the system, as i had to vent one of the rads a lot, could there be an airlock in the primary flow throught the cylinder?
Whats the best way to remove this (if there is)
