    Dismiss Notice
Changing 3 gang light switch to 2 gang
Discussion in 'Electrics UK' started by Marc1912, 13 Apr 2020.
  1. Marc1912
    Marc1912
    13 Apr 2020
    8
    Thanks Received:
    Country:
    Hi there,
    Here's a little problem which I hope has an obvious answer.
    I have a 3 gang light switch: two of the switches individually control 2 separate ceiling light circuits in the sitting room; the third switch operates the cellar lights (great arrangement o_O). All the circuits are 1 way.
    I want to replace the three gang switch with a 2 gang (one dimmer, one on/off) switch. I would like the dimmer to operate all the ceiling lights at once, and the on/off to control the cellar lights.
    Question is can I wire both light circuits to the dimmer so they operate together?
    Thanks,
    Marc.
  2. Sponsored Links
  3. Taylortwocities
    Taylortwocities
    28 Jul 2006
    19,133
    Thanks Received:
    1,924
    Oxfordshire
    Country:
    Yes you can.
    Make sure that the lamps are dimmer-able and that the dimmer is compatible with them.
  4. Marc1912
    Marc1912
    13 Apr 2020
    8
    Thanks Received:
    Country:
    Great, thank you!
Loading...
Share This Page
