Hi, my heating timeswitch needs to be changed. Presently I have a landis & staefa rwb7 (which seems to have gone off the market). I was given a towerchron qe2 so I'm wondering if anyone knows if it's a compatible change?
A Landis & Staefa rwb7 is a simple single channel timeswitch with a single on/off switch to control just one thing, usually the central heating
A Towerchron QE1 is a single channel timeswitch the same as a rwb7. However, the Towerchron QE2 you mention is a dual channel timeswitch and has separate control for Central Heating and Hot Water (ie a stored hot water cylinder)
