Changing a UpVC door frame
20 Jul 2010
Liverpool
Hi All,
I am trying to find out if i can change the size of a UPVC door frame. The reason, I have been given a Upvc door but it has another glass piece in the top above what would be the door and the door frame.
I would like to remove the piece of glass from above the existng door frame and cut down the extended piece of frame so it fits snug round the door. Does anyone know how this is done.
thanks
c :)
Plastic frames are welded, so unless you have the machinery, you can't alter them
However as a "make-do" solution, whether you can just lop the fanlight section off will depend on the joints there - they may be weak if you do this
