They should not require bleeding if you have done the job correctly.
Unless of course you opened the bleed nipple to let fluid out while pushing the pistons back into the callipers?
Does the brake pedal feel spongy? if so, there is air in the system, and the brakes will require bleeding.
Also new pads do need to bed in, no harsh braking for the first hundred miles or so.
Wotan
