Hi chasing out for wires and sockets for rewire, the old metal pipes may well be stuck with the old wires in them, we couldn't budge the old cooker wire when replacing it.
So i have found a much easier route to eliminate 2 pipes if it is acceptable.
a breeze block wall dot and dabbed on both sides.
i could use the space to chase wires down the corners where it meets the concrete walls.
if i have read in Wiki correct wires in 150mm don't need capping or insulating but i would like to do this anyway.
Is there a required depth for this 150mm zone? and the horizontal stretch to the sockets would this be different as being out of the zone?.
Will the width of a breeze block wall i think 5 inches? be acceptable to have sockets with in the plaster board covering.
It will mean that one one side of the wall in the kitchen which is dot and dab there will be 2 x db skt and on the other side of the wall which is dot and dab in the lounge will haven 1x db skt.
OJ
OJ
