cheap insulation for shed?
16 Sep 2010
Merseyside
I have a 10ft x 10ft shed that i work most nights in rebuilding a motorbike (mrs has refused me access to the house with bike bits)
The shed is made from t&g shiplap. i have clad the inside of the shed with sheets of 10mm mdf, which has stopped any draughts, but i now have voids in between each of the joists (the vertical lengths of wood along the walls)
i was thinking of removing all the mdf an stapling bubblewrap then putting the mdf back on
or
filling the spaces behind the mdf sheets with foam pellets?
ideally i dont want to spend alot as im told the shed has to go in a year or so when we get an extension built
hope all this makes sense
thanks
What bike dude? (I know it’s not on topic but I’m nosey). :D
I’ve got a VSTROM. 8.5 years old & 62,000 miles I’ve done from new.
Oh, here’s on topic... In a program I saw, I think it was grand designs, they used hay
It’s cheap and has wonderful insulating properties. There were other advantages too, but I can’t remember them now.
So maybe stuff a load of that in between. :idea:
Well there's a right way and a cheap way,
As you'll be knocking it down shortly I'd go cheap(!)
What do you already have? If you have a load of bubblewrap then go for it.
General rule is that solid insulation or plasticy stuff (bubblewrap) should have airgaps etc for condensation.
If you have nothing go for the cheapest fiberous stuff,
It's only really to take the edge off anyway isn't it?
Then when you rip the shed down, bung it up your attic.
As already asked above, what bike?!
I'm currently building the man shed for my fleet:
CBR900RR, VFR750RC24 (x2), Z750
I'll be experimenting with a solid filled, sealed void with no air gap (sacralige!).
I had the Z750 twin, (P reg 360 deg crank), and 750 4 cylinder Kwack L1. (The first 750 with 1,000 cc like performance).
Soz for drift. In the same way a biker cop is a biker first and cop second, I'm a biker first and a DIYnot member second. :D
ahh cheers for the suggestions all
i have "borrowed" a roll of 1.5mm foam, that my work use to wrap fragile items. it looks very similar to the cheap insulation for laminate?
the bike isn't that exciting really, its a 600 Bandit, that i got for basically nowt (£100 :shock: ) callipers are seized - general rust...tidy up
i finished rebuilding a CG in the summer, an just fancied another project
CG
Bandit
I had a CB125 in the late 70s :D Got it for £10 off a work colleague's back garden. It was a rat bike for the winters. Unburstable engine! The CG came out afterwards. I think, if memory serves me well, it was a push rod engine instead.
Ahh memories... :)
If the shed is coming down in a year then I'd simply screw sheets of insulation board or thin cleotex on the inside face of your mdf lining then as said reuse the insulation for something else. Cheapish quick and simple. As you have some thin foam stuff just staple that on the inside of the mdf , I really wouldn't go to the fuss of taking down the lining.
Any bubble wrap or insulation 3mm is waste of time. Look out for some left over celotex or kingspan on ebay near to you.
