Cheap(ish) DIY way to replace a garage side door with unusual frame size?
24 Jan 2019
I've got a garage, built in the 70s. The side door is rotten, as is the frame. The 'hole' in the brickwork for the door and frame is 200cm x 93cm, which doesn't seem to match off the shelf UPVC doors and frames that I can find anywhere online. I'm not keen on having another wooden door, because I am too lazy to maintain it, and they can be a pain to open/close in winter.
The best thing I can fine with an internet search seems to be this metal door:
Security garage door.
They will make it in a reduced height, and sell me something pack out the frame width. However what looks good to my ignorant eyes might not actually be! So, is there a better off-the-shelf option, or any reason not to go with this (or similar)? Ideally I'd like to keep the price down, so fancy custom made stuff is out.
Many thank!
Found lots on line to fit here’s one.
Thanks. I wonder why I didn't find any? Also I should have said, mine needs to be outward opening and ideally not have any glass panels, or at least any glass panel big enough for a human to fit through after they've smashed it!
A Latham steel door is a commercial grade door and will be much more secure than a UPVC one, they're beasts. BTW they weigh a lot, also you'll likely need to add a few extras to get to your final price. But out of all of the online steel door suppliers they are the cheapest and actually easiest to order from as a domestic client. I bought one for my garage a year or so back though I went for the Security Steel Door which upon reflection was probably overkill, I also specify Latham doors regularly as part of my job for commercial plant rooms, personnel doors etc.
