So i was looking at this today as i wanted to notch this myself, but thought it looked like a bad idea as the support i wanted to notch was for a chimney that had been removed on the floor below.
This lead me to notice that it looks like the whole support is resting on one tiny bit of wood... In which case i need it sorted, here are some photos, hopefully they aren't too hard to put together:
The bathroom is question I have circled the area in question:
This is closer up. The chimney stack i resting on a makeshift beam (numbered 1) this is resting on a 'piece of wood'/support (numbered 2) which is then screwed into an additional beam (numbered 3) which is in turn notched into the joist (numbered 4).
The beam numbered 3 in the previous photo has then itself been notched to allow a waste pipe through.
Leaving what seems to be this tiny 1 inch piece of beam 3 as the sole support for one side of the chimney breast.
