- Joined
- 12 May 2020
- Messages
- 37
- Reaction score
- 1
- Country
Hi
We’re renovating a room with a chimney breast in it.
As it’s an external wall, the plan is to put stud work against the back walls and all the way around the chimney breast, fill with 50mm of celotex and plasterboard it.
This has 2 advantages: (1) it should be warmer and (2) the small cavity behind the studwork (5cm or so) allows me to drop cables rather than chase them in.
The question is whether, if I stick a 9” by 6” vent on the chimney breast, there will be sufficient air flow behind the celotex to keep it dry?
thanks, Ben.
thanks, Ben.
