I have a small chimney that is now defunct. It used to serve the original Arger back in the 1930s.
To keep costs down (prior to me moving in) the chimney was removed at kitchen level to give more space but retained at first floor and above. The chimney was also sealed at the top and bottom. No ventilation slats visible.
This was all done before I moved in.
Ever since I can remember I have had a small damp patch (which never grows or gets mouldy) in the bedroom onthe other side of the wall where the chimney runs against. The chimney runs internally within the house and not against an outside wall.
My thought is that the capping top and bottom is the cause, somehow, of the damp.
This was recently reinforced by my adjoining neightbour who has had the same work done to the chimney in the distant past. They also have it capped and no ventillation and have the same damp patch in the same place in the same bedroom.
The flashing, although old, looks to be fine.
So, my thought would be to uncap the chimney top and put a pot on it. and drill a hole internally for an air vent and get some ventillation into it?
The only thing I can think of is some odd temperature differential which is causing condensation/damp in a certain spot?
Thoughts?
Thoughts?
