chipboard flooring
14 Jul 2004
I want to put down chipboard flooring and then seal it - not cover over it. Has anyone done this before?
Forget Chipboard, I have it i my extension and its horrible. Anytime anyone walks across the floor you can feel yourself bounce and it creaks a lot. In the kitchen water got onto it and destroyed the tongue & groove join between two sheets and there was no support underneath. When I had my loft extension done, I made sure I got wooden planks and have had no problems. Another problem is if you need to lift up the floor, it comes in large pieces unlike ordinary planking
Has anyone got any tips for stopping a chipboard floor from creaking ?
rub talcum powder into the cracks
also check the screws are tight
big all
Im putting the stuff in my loft as a cheap alternative. It doesnt get that much wear in the loft so it should hopefully be ok for about 10 years
putting in your loft is fine, as long as you dont spend a lot of time up there.
John, from what you have said it does sound like your floor wasn't laid properly.
