What ho one and all,
Want to buy some multi-coloured, mains powered string lights to put around a tree for Christmas. Built-in timer (8 on 16 off) essential. Having difficulty finding a 15m length of lights (may be 20m overall) but have found this
https://www.robertdyas.co.uk/robert-dyas-mains-operated-led-string-lights-multicoloured.
Is there any reason why I should not cut to 15m LED length and re- attach the 10m from plug to bulb? Obviously, it would need to be waterproof.
You will find that these "strings" of LEDs are `actually multiple "sub-strings" of (possibly) 10 Green - Blue LEDs in series paired with 10 Red - Yellow LEDs in series (plus a current limiting resistor in each half sub-string) - so that the voltage drop adds up to the supply voltage.
Each of these series strings are connected in reverse parallel and supplied by the "adaptor" with about 32 V DC.
The "Adaptor" contains a "Switch Mode Power Supply" {SMPS) which derives this voltage from the "mains" and uses "electronics" to supply the voltage concerned in "pulses" - each pulse being in the reverse direction to the previous pulse - and having "pulse width modulation"..
Thus, when it appears that all LEDs are "Full On" they are NOT, but each half sub-string is turned ON and OFF so rapidly that it appears to human eye that they are "On" at all times.
When it is required to make the LEDs brighten or dim, the length of the full-on pulse is adjusted accordingly, so that it appears that the LEDs in each half sub-string are brightening or dimming.
Because of this, the complete "string" comes in sets of "sub=strings" of (say) 20 series/ parallel LEDs.
Each of these sub-strings (of 2 series strings plus the "return" wire) is fed by only a "pair" of wires, similar to the "feed" from the "adaptor" to the first sub-string.
Thus, one can cut the "string"
only at a point where one sub=string connects with the next, via a 2-wire connection.
If such a cut is made elsewhere (to
3 wires), the LEDs beyond the 2-wire connection point will no longed function - unless suitable connections to the "Return" wire are made and appropriate additional current limiting resistors are supplied..
