Afternoon all,
My kitchen ring has over the last week been tripping inconsistantly, sometimes taking the RCD down with it, other times just the mcb for that circuit.
I suspect that the outside socket which has a fused spur off the ring may be getting wet in this recent wind/water weather event we have had recently.
The RCD is completely knackered now - it wont reset down, to bring back up so will be replacing that, meanwhile is there any recommendations for 3 pole isolator that i can fit on the spur to disconnect outside all together when not needed? I will be getting outside to check/reseal the outside socket hopefully over the weekend but thought if i can get an isolator then at least i can disconnect from inside the house.
