I have a job for the company i work for to install a power pole for sockets supplying computers.
I have been told to fit a new OPD at the consumer unit and run a 6mm twin and earth cable to a 32amp switch mounted in the power pole. Then to run a ring final circuit within the pole for sockets.
I understand that the protective conductors within the ring should be terminated in separate earthing terminals in the sockets due to high protective conductor currents but would i have to run a separate protective conductor with the 6mm radial?
Also how many computers would need to be connected to the circuit for the total protective conductor current to exceed 10mA?
any answers appreciated thanks.
