I'm looking for a new circular saw, ideally one which is guide rail compatible, though not an absolute must as it's only for DIY use.
On the guide rail front, I'm thinking I'll buy a guide rail anyway even if I buy a circular saw which isn't compatible. Probably something like the Evolution ST2800 from Screwfix for £70 - I'm fed up of bodging guides with bits of wood, spirit levels, etc. and I want a decent guide I can use with other tools such as my router which isn't compatible with guide rails anyway.
From experience and a brief look at various models in a store, I'm thinking a 185mm or 190mm model is an appropriate size for my needs. Are either of these two sizes more common than the other i.e. will they open me up to a wider variety of blades?
I'm a massive fan of Bosch Pro stuff, having several of their drills and other tools, however it would probably be the GKS 65 GCE if I went with Bosch - that along with a guide rail to cover 8ft brings me to about £400 which is more than I want to spend really - ideally I'd be looking closer to £200.
Which leads me to look at models such as the Bosch GKS 190 which can be picked up for around £100, or the Makita HS7611J which actually looks a better model and can be picked up for a similar price. Or alternatively I could just go with the evolution R185CCSX+ though I don't have much experience of them - that's also around £100 and is compatible with the rails as well.
Is there anything else you would consider? Am I going to get a decent saw and guide rail from a decent brand like Bosch or Makita for this kind of money or are the models I'm looking at about the best I'm going to get? If I'm looking in the right kind of ballpark for my budget, would you go with a guide rail compatible Evolution or go with a better circular saw and simply use the guide rails as a straight edge with integrated clamps?
Any other thoughts?
Any other thoughts?
