Personally if the pump is working and motorised valves are working ok and the system is full of sludge i would be checking for a blocked cold feed or partial blocked cold feed. If there is poor circulation this can certainly be responsible.
holty said:simple rule for an openvented system is vent then feed then pump, with the vent and feed 150mm apart. simple
Agile said:holty said:simple rule for an openvented system is vent then feed then pump, with the vent and feed 150mm apart. simple
I would suggest 150 is a maximum and they should be as close together as possible and ideally on a straight horizontal section of pipe.
Tony
holty said:and how a basic heating system works.
JohnD said:H'mmm, used to work, after 20 years it doesn't.
Over time, sludge builds up.
Coincidence?
holty said:he should of firstly arrange the vent feed pump arrangment
holty said:sorry got halfway down a page about trying to explain about negative and positive pressures and how heating systems should work, then deleted the lot. because it would take me to long to type . also as a paying customer its not your job to try and find out on this site how to solve your heating system for the plumber your paying. or is this a wind up
