Circumstances for NC contactor?
Discussion in 'Electrics UK' started by Mike2007, 14 Oct 2021.
  1. Mike2007
    Mike2007
    10 Feb 2007
    1,346
    Thanks Received:
    35
    Cumbria
    Country:
    When is a normally closed contactor used (not normally open)?
  2. Sponsored Links
  3. EFLImpudence
    EFLImpudence
    7 Jul 2010
    37,819
    Thanks Received:
    4,260
    Retired to:
    Country:
    Portugal
    When you want to switch off something when the contactor is energised -
    it saves having to power the contacter continuously for items that are usually on.
  4. JohnW2
    JohnW2
    28 Jan 2011
    49,209
    Thanks Received:
    3,251
    Buckinghamshire
    Country:
    Well, such functionality might be wanted for all sorts of reasons, albeit I would imagine extremely rarely in relation to a domestic electric installation.
    One reason for wanting it is so that the 'default state' (e.g. if there is a failure in the supply or circuitry controlling the contactor) leaves the contactor contacts closed, hence any supplied equipment 'on'. It may sometimes me more appropriate/desirable to have a contactor (in its activated state) 'switch something off', rather than 'switch it on'.
    Kind Regards, John
    • Like Like x 1
  5. bernardgreen
    bernardgreen
    3 Nov 2006
    26,052
    Thanks Received:
    2,597
    Bedfordshire
    Country:
    Battery powered emergency lighting can be switched via the normally closed contact of a contactor whose coil is connected to the mains.
    Sometimes where a contactor is normally ( quiescently ) energised the contacts are labelled in the circuit diagram as QC ( closed when coil energised ) and QO ( open when coil energised )
    • Like Like x 1
  6. 333rocky333
    333rocky333
    12 Jan 2008
    8,467
    Thanks Received:
    919
    Essex
    Country:
    We use them for store and car park lights, by using them, not done the maths, but apparently the coils are energised for a shorter time during day turning lights off, than overnight with the coil turning them on.
    The contactors seem to last longer.
    Also as John says if the contactor fails the lights default to on till replaced
  7. Sponsored Links
  8. ericmark
    ericmark
    27 Jan 2008
    18,944
    Thanks Received:
    1,780
    Llanfair Caereinion, Nr Welshpool
    Country:
    I used them with compressor de-load valves, if valve is opened at start and the valve leaks there is too much pressure in cylinder for it to open so it ruptured the fuse, but if de-energised on run then since held open the pressure can't build up in the cylinder.
  9. oldbutnotdead
    oldbutnotdead
    11 Jan 2013
    4,769
    Thanks Received:
    1,006
    Durham
    Country:
    Very handy (in large buildings with no windows) having the NC connected to indicator lamps on light switches....NO connected to the actual lights
  10. bsr
    bsr
    5 Aug 2008
    618
    Thanks Received:
    55
    Gloucestershire
    Country:
    Electrically controlled door locks eg mag locks?
  11. SUNRAY
    SUNRAY
    28 Jul 2009
    5,856
    Thanks Received:
    451
    Kent
    Country:
    Most of the controlled lighting circuits in supermarkets is with NC contactors.
    Typically the lights are on for around 18 hours a day and these days big supermarkets are 24 hours.
    The lights are often controlled by a BMS (Building Management System) so an added bonus is the lights will come on if the BMS fails.
  12. crystal ball
    crystal ball
    28 Apr 2004
    5,543
    Thanks Received:
    340
    Country:
    In ye olde relay logic systems NC is used to switch other relays or devices as required
Loading...
Share This Page
