Just recently my RCD kept tripping when British Gas came out the first time they said the RCD was faulty, they would send someone out to fix it, they then said the RCD was ok it was the tumble dryer and not to use it. However when he left it happened again this time they said it was the electric oven as it tripped when it heated up, so i was advised by British Gas to have the oven checked. I have had the tumble and oven done. i was also advised that the sockets to my conservatory was on a 32amp which is wrong, due to the wire being larger !!! he said i would be able to put them on a 20 amp,so i have changed it to a 20 amp but it trips the rcd off and doesn't work. They worked ok when they was on a 32 amp.
I have turned off my garage flouresent lights has they keep tripping the RCD aswell
Please advise what to do with the amps
