hi all,
i have pulled out my old cloakroom suite and put in a new one however before screwing pan to floor i have put down insulation and laminate flooring thus the toilet being some 15mm higher than it was originally(screwed into concrete foor with carpet cut round)
the problem i have now is the feed which has an isolating valve on will not meet the cistern bottom inlet ballvalve.i want to keep the pan on the flooring i can only think of taking the isolating valve of and and cut pipe back to fix a longer piece of pipe then put iso valve back on and hopefully it will then meet up.
the gap in question is about 20mm,i hope someone who's got more of an idea than me can help
thanks
thanks
