Cistern Syphon failed....
3 Sep 2006
Cheshire
My bog no longer flushes, it has a standard syphon installed, Im thinking of getting this part as a replacement......
Fluidmaster Pro Series PRO750UK lever operated dual flush valve
This will fit & work as a direct replacement won`t it :D
Toilet is a close couple cistern.
remember don't twist the wrong way or else you will be taking to bog apart , because a lad who worked for me done it three times in the row :mad:
If you're on a water meter don't replace an almost trouble free syphon for one of those.
I 'upgraded' all 3 toilets in my house with Fluidmaster push button flush and fill valves as they'd all been heavily bodged - 2 1/4" hole in the bottom of the cistern with a 2" valve used plus loads of silicon, water hammer from the fill valve on another, another one constantly trickling out of the overflow, just wanted to be done with it so ripped the lot out and started again.
What's up with them if you're on a meter? I'd have thought it'd be better as I now have a half flush function?
When you get the constant trickle into the pan, and you will, you can end up with huge water bill unless you sort it pretty damn quick.
Easy way to check , put a pice of ****e Roll on the outlet of the pan ,,,, at the top where water comes out ,,,,,, if it gets wet u have a failed washer
If and when you need spares try these guys.
www.buyplumbingonline.co.uk
I don't work for them but used them for the 3 Siamp valves I have here. All 3 were less than a tenner, delivered for free and ordered at half 8 on the night and still delivered next day at about 1!
Always happy to promote good service!
Jon
