Hi new to the forum
I have a Berlingo 2.0HDI van 2005. I have recently changed the power steering pump due to it leaking. Fluid had dripped onto the Alternator which is directly below. This eventually burnt out I have replaced the Alternator this morning and when i have fired the van up the steering is very stiff. Checked the power steering fluid level and its fine. Seems as though the fluid isnt recirculating around the system..Have removed the top solid pipe that goes into the top of the pump reservoir, cranked the engine over and fluid came out under pressure. The van has stood for a couple of weeks when i was waiting for the new alternator. Could there be a blockage in the lines due to it standing for a couple of weeks and debris settling in the lines? If so could it be unblocked by blowing through with and air line?
Any advice appreciated
DEKA
DEKA
