citroen piccaso a/c and fan
14 Jan 2007
Sussex
help!!!!cant see out of my windows no more... the air con and fan dont work anymore,fuses seem ok and no loose wires seen,any ideas please
Hey
I hade the same problem with my VW Passat mate rotten luck it is i had it since november i had something about that i'll find it and tell you keep looking you might get lucky.
Westside7
I think the system on the Picasso incorporates a diagnostic self test but a code reader is needed.
When you say "the fuses seem o.k. have you tested them with a circuit tester ?
Have you got the Haynes Manual for reference. ?
Have you checked that the pollen filter is not blocked ? If you have checked the filter and fuses it could be the air con.relay,it could be a few things, so I would go for a readout to point me in the right direction and save a lot of time, guess work and money.Best of luck.
