Citroen Xsara Picasso ECU fault.
23 Feb 2006
Dorset
Hi folks
Can anyone help me with a fuel injector fault on my Xsara Picasso 2.0Hdi registered 11/01.
The ECU is a Bosch EDC15C2 unit withsoftware 9642014980.
The fault codes are: P0201 No 1 injector circuit fault
P0204 No's 3&4 injector circuit fault
Thanks and regards, Hairyjon :confused:
Hi Masona. Thanks for the info. I have checked the links you gave me but unfortunately it is not a pin corrosion problem. There seems to be an internal fault with the ECU. I have stripped it and re-soldered about 200 joints and it did about 200 miles and then packed up again now it won't run at all.
I wish I had kept my Volvo 940!
Hi Masona. Thanks for your help but it didn't :cry: I have a couple of other suggestions from www.woodworkersinstitute.com That have been quite helpfull. You might like to visit the community section if you are interested in wood in any way. I'm in there under the same name! :D
Thanks, I shall have a look at that as I do carpentry and also now do stained lead light windows
