Cladding gable ends advice
17 Feb 2010
Somerset
I'm planning to get the gable ends on my bungalow cladded, partly to make it look more modern but also to reduce the maintenance, easy painting the rest etc. My walls are currently rendered so what options do I have and what would people recommend?
I was thinking maybe cement weatherboard, something like Cedral but we had one guy we know come round and recommended Freefoam Double Shiplap cladding?
When fitting it, does in need just battens presumably or should there be anything else in the installation that I should be considering? Like insulation or some sort of membrane and should there be a gap for ventilation? We will probably have to replace the fascias in those areas at least otherwise the future replacement may become more difficult. Any advice would be much appreciated.
My bungalow is finished with Cedral, just nailed to ply walls ( so different construction method , but yours could be fitted to battens .I would not use a membrane as you need to keep the original render well ventilated .
Thanks Foxhole much appreciated. I've also heard Hardie planks mentioned as a decent option? Any views on them rather than Cedral? Or is the Freeform UPVC decent? Thanks
I would use cement board planks rathetr than uPVC - less risk of expansion issues.
