Lost a clay ridge tile in the storms. One close to gable end. This was a weighty beast 46cm long 90 degree red clay tile on a 1930's house with slate roof. That was some gale. I have sourced a replacement from a reclaimers.
I've not been up there yet - I'm having to invest in a long ladder - but it looks as if there are a couple lumps of cement remaining in situe on top of ridge. No cement came down attached to the tile so I imagine the old fixing material is still up there.
Any advice on preparing the roof (in terms of old cement) before fixing please. What do I fix replacement ridge tile with and how? I've read 3:1 sharp sand mix but won't it just slide down the roof!? Do I fix then point. How much do I use to fix - a bed under each flap, a couple of spots on ridge itself? Do I leave time between fixing and pointing? Does it need to be dry for a few days before/after fixing? I'm probably over worrying on what is a simple job!
