cleaning cement from brickwork
Discussion in 'Building' started by RMB, 16 May 2006.
  1. RMB
    RMB
    2 May 2005
    23
    Thanks Received:
    Hertfordshire
    Country:
    After repointing some bricks are smudged with cement.There is a type of brick cleaning acid-will this be able to clean the bricks?
  2. sandwell
    sandwell
    1 Apr 2005
    324
    Thanks Received:
    Country:
    ? Do you mean smudged with mortar.
    I think it is very difficult to remove except by wire brushing. All the patio and brickwork cleaners will clean the mortar as well as the bricks.
  3. Sponsored Links
  4. Mick Leek
    Mick Leek
    16 Nov 2005
    370
    Thanks Received:
    Country:
    Some of the brick cleaners WILL remove cement stains. The downfall to this however is that the way it does it is by breaking down the portland cement within the motor.
    Unfortunatly this will also breakdown the new pointing. Ensure you choose wisely and ask at your local builders merchants.
    Good luck
  5. RMB
    RMB
    2 May 2005
    23
    Thanks Received:
    Hertfordshire
    Country:
    I will do that-thanks for your advice
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
