Would appreciate advice/opinions from those with experience...
I am about to order materials to replace a 33m run (approx) of closeboard fencing. Fortunately, the old mortised concrete posts are in good nic, still vertical and stable so I'll make use of them. I purchased materials (arris rails & brackets and feather edge wood (100mm x 1800mm) for just one panel from the nearest wood merchant (Alsford Timber) and replaced one section of the fence. It went well so I intend to replace the lot myself.
My question concerns wood quality. Firstly, is the 30% price difference I've noticed between local, long-established wood merchants likely to reflect wood quality? Only the wood I purchased for the one panel I've completed wasn't impressive - the featheredge boards felt as light as balsa wood when dry. In contrast, the old wood, whilst rotten at the bottom, is noticeably heavier/denser when dry and it's probably around 45 years old and not been treated in the last 25 years, if ever. Can't see the new wood lasting anywhere near as long. Of the three arris rails I purchased, one had a bad knot/crack that affected strength. I collected the wood from the yard so should have been more vigilant but if I order the remainder, I'll have to get it delivered - god knows what may turn up! Any tips on getting the best quality wood for the money? I don't mind paying for quality but I do mind paying for substandard materials. Do some wood merchants have particularly good or bad reputations? Thanks.
