I'm slowly converting a garage to a utility and downstairs loo. Everything so far has been DIY, although electrics will need signing off by a Spark.
It's not a huge space (loo is approx 120cm x 70cm) so want a fairly compact loo, although door is opening outwards.
I've built a false wall (floor to ceiling) on the left of that door (out of shot), to hide soil pipe, some plumbing, cabling etc. There is 20cm behind there, so can easily fit a concealed cistern, and this would allow more space.
I'm just concerned about access if it needs repair/maintenance. Creating an access panel (probably tiled hardiebacker with hidden joins...?) , makes things a fair bit more complex to do than just a false plasterboard wall with pipes coming through. Do most people include access or do they just board it up and hope than it never needs more maintenance than the things you can do through the flush plate?
I'm pretty confident I can install the Close Coupled version, just not 100% on the concealed having never done one before.
