- Joined
- 3 Jan 2018
- Messages
- 150
- Reaction score
- 4
- Country
Evening all,
I will be replacing my old 70's style S trap toilet with a more modern P trap version. As such I need to core drill to the outside and connect the soil pipework to the following:
I am a little unsure of the best connection setup to use.
I have a push fit 90 degree bend, which I believe the hole in the wall will need to be big enough to take the wider rubber sealed end to minimise leakage at the join.
Do I use a straight of 110mm pipe to go through the hole in the wall, and do I need a pushfit flange on the inside for the toilet pan connector to push into or does it fit into the straight part and form its own seal?
Secondly how much of the pipe going through the wall do people leave proud on the bathroom side? I couldn't find white so it sticks out a bit being grey.
Connector I am considering buying:
And lastly what is the best way to connect a double socket branch to the clay soil pipe?
The clay pip isn't large enough to take the branch directly so assume there is some form of adapter which is them mortared in?
