- Joined
- 27 Jan 2008
- Messages
- 27,547
- Reaction score
- 3,329
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
My dad bleed his radiators and when I arrived he had zero pressure shown on gauge. However the boiler was still running and some radiators were hot.
Should not the boiler have closed down? Central heating less than 6 months old so should be under guarantee.
Also all lock shield valves were wide open should these have not been partly closed?
Last there was no TRV in hall where the electric thermostat is located. I thought the electric thermostat is only to switch off system in summer and for the variable output boiler to work one must use TRV's?
Please say if wrong but I thought the boiler senses the return water and adjusts flame height to keep return water cool enough to ensure the condensate is formed? Therefore on modern system ALL radiators have TRV's.
I know with old boilers the standard system was to have TRV on all but coolest room and the coolest room used a electric thermostat. But I also was under the impression since the introduction of variable flame boilers the electric thermostat is only to switch off system in summer?
In fact the thermostat could be fitted outside or in non heated part of house.
But before I contact the installers I want to make sure I have it right.
Already I have called them back as they fitted a combi boiler to the existing power shower and I got them to change it for a thermostat valve type. From what I understand that was against the law so I don't have much faith.
