I have recently had my old Back boiler removed and replaced with a new Combi Boiler which is located elsewhere.
I intend to brick up the opening in the chimney and include an airbrick for ventilation
Before I brick it up, as you can see from the picture below there is still a flue liner in the chimney, that was previously attached to the back boiler.
What i need to know is if the liner needs to be removed before the opening is closed.
As if it does I will need to get someone to go on the roof and remove it.
