Hi all,
I have a Dispatch van, 58 plate, 17000 miles, bought from new. I do not carry huge amounts of weight and do not make loads of stops per day.
I have recently had to replace the front brake pads as they were 95% worn.
I have been out with mechanic from garage today as also have some clutch judder. This occurs intermittently in 1st and 2nd gear.
I have not been, so far, impressed with the aftersales service from this particular garage. And have felt like I have been fobbed off several times.
My question(s) are should the pads require replacing after 17000 miles? A car would maybe do 40000 miles per set of pads I read. Is a van half this?
And should I be getting clutch judder after this kind of mileage?
I do not 'rag' the van, but then I am not a sunday driver either!
If the above should be doing 50000 miles then do I have any recourse? Could I possibly argue that the parts must be inferior/naff quality and push to get them replaced before 3yr warranty expires.
Any help or thoughts welcomed.
Many thanks.
Many thanks.
